TAB Aircraft LLC Web Site
Searey LSX
Modifications
7-24-2012
N/A
Page 25 Actuator Plate Replacment
July 29 2012 Continued.
I then removed it and used the original Gear Plate as a templet and traced the shape and the bottom holes and cut the shape and drilled the bottom hole.
I ground the edges smooth and mounted the plate.
Before
After from the back
After
Searey LSX Home
800
Aircraft
Airframe
86
Background
Brakes
Cockpit
67
130
Education
Exterior Trim
Fly-In/Party
Gear Assembly
Hull
Interior Trim
Modifications
Turtle Deck
Wiring
53
131
Work Shop/Hanger
