An option that Progressive Aerodyne is installing on the Factory Seareys looked a lot better than the Foam Grips that came with the kit plus it looks like the Joy Stick I got for my computer. It even has a trigger for a Machine Gun or a Air to Air Missile. Unfortunately, Those are to heavy for a Searey, So I guess I'll use it for the Radio Mic Button, and the Top Hat Button for the electric Elevator Trim. To bad the plane don't have a electric Rudder Trim for the left/right part of the Top Hat Button.
I cut the Control Sticks just below the bend and filed the cut smooth and installed the Tosten Grip on each one. I then installed the Control Sticks on the Control Column Torque Tube and then adjusted the Tie Rod Tubes.
Installed the Tosten Grip on each one.
Installed the Control Sticks on the Control Column Torque Tube and then adjusted the Tie Rod Tubes.
