Brief Description: Page 44 Attaching the Rubber Seals
August 15 2012
Attaching the Rubber Seal to the Transom Manual Ref: S5- 22.1 to 23.2
Drilled the holes for the screws in the Transom, glued the Rubber Seal to the Retaining Ring and glued and screwed the Assembly to the Transom.
Attaching the Rubber Seals, Main Gear to the Sides of the Hull Manual Ref: S5- 30.1 to 35.5
Drilled the holes for the screws in the left and right side of the Hull, glued the Rubber Seals to the Retaining Rings and glued and screwed the Assembly to the Hull.
