TAB Aircraft LLC Web Site
Date:  7-22-2012
Number of Hours:  3.00
Manual Reference:  S5- 1.1 to 4.5
Brief Description:  Page 23 Cutting the Hull for the Airframe
July 25 2012
Section 5, Installation of Airframe into Hull
Manual Ref: S5- 1.1 to 4.5
Measured and marked the Hull Transom for cutting. Locating the exact center of the Transom was tricky because of the shape of the hull, but I got it done.
Cutting the Boom Tube opening with a electric saw did not go as smoothly as I hoped and the hole ended up a little larger than was measured, but I know a foam tape goes between the Transom and the Boom Tube so I am not to worried
Hull marked for cutting
Hull cut
Hull cut
