Brief Description: Page 518 Getting the Play out of the Lower Gear
September 24 2015
Getting the Play out of the Lower Gear Legs Part 1
While checking the Gear Electric system and jacking up the plane off the floor, and raising the wheels off the floor. I saw why my wheels had a camber issue. The lower Spindle Assemble would pivot on the one bolt holding it on the gear leg. It would move up and down a quarter inch at the tire. I think the paint on each part had worn down and the fit tolerances got bigger.
Drilled out the rivets holding the gear leg fairing
Removed the bolt and slid the spindle off and cleaned the area
