TAB Aircraft LLC Web Site
Date:  2-17-2014
Manual Reference:  N/A
Brief Description:  Page 459 Reinstalled the Dynon Intercom
March 5 2014 continued.
One of the issues I had with the Center Panel was there was no room for mounting screws in the middle section, and the middle bowed out a little. I made a TAB to help hold the Center Panel to the Fiberglass Dash and used the Intercom mounting screw to hold it all together.
After I got it mounted and all the FastStack Cables back on, I tried the Gear Warning wire on the Muting and Non Muting Wire and it worked on the Muting Wire, but not on the Non Muting Wire.
Next I need to cut the connections off those wires to see if the shielding is grounding the wires.
Made a TAB to help hold the Center Panel to the Fiberglass Dash
Tab on the mounting screw to pull the panel to the fiberglass.
All put back together.
