Brief Description: Page 425 Installing the Transponder Antenna
December 14 2013 continued.
Installing the Transponder and ADSB Antennas
I drilled a mounting hole in the bottom of the Leading Edge on each wing near the Strut connection. I then installed the two antennas and connected the wires and then zip tide the antenna wires to tubes inside the wing I could reach through the inspection holes to keep them from rattling in the wing.
Drilled a mounting hole in the bottom of the Leading Edge on each wing near the Strut connection
Installed the two antennas and connected the wires
