I installed the Male Antenna Connectors to the RG400 cables coming up from the Pylon.
I purchased custom made RG400 Antenna Cable cut to length with male and female connectors from Aircraft Spruce and fished them through each wing to put the Transponder and ADSB Antennas out on the under side of each wing and away from my head. I drilled a hole in the plywood end of the wings and ran the female connector out into the space between the wings and connected to the male connectors from the Transponder and the ADSB.
I also ran power and ground wires for the 12 Volt Power Outlet in the cockpit and promptly blew up the charger for my DVR Camera in the cockpit. I had the ground and power reversed.
Transponder Antenna waiting to be installed under the leading edge of the wing
