Brief Description: Page 372 Glued in the rear windows
October 9 2013
I wanted to install the rear windows without the rivet in look. The Stow-n-Go Hatch I installed could be installed with rivets showing around the outside edge or the better looking way, fiberglassing it in for a cleaner smoother look, which I did. But the windows are suppose to be riveted in the indention on the top side of the hatch window frame. I did not like that look. Why go to the trouble of glassing in the hatch frame to get rid of the rivets only to have rivets around the hatch window plus the Plexiglass edges showing. I decided the Plexiglass would look better on the inside of the frame and gluing it in got rid of the rivets around the hatch window frame.
I tried using the double sided foam tape that is used for body side molding, but it did not hold on to the Plexiglass very well.
Used "The Right Stuff"
I saved this decal for years just to put on my own plane. They don't make this one anymore
