TAB Aircraft LLC Web Site
Date:  9-3-2013
Number of Hours:  3.00
Manual Reference:  N/A
Brief Description:  Page 334 Making the Viking Switch Panel
September 3 2013
I extended the rest of the switches and drilled the holes in the left side wing panel. I was not happy with the holes I drilled. They did not line up straight and one hole was to big.
The Key Switch ended up to close to a Switch Guard, so I cut out a new panel out of some scrap aluminum and re-drilled the holes more carefully.
I then decided to put the Hour Timer on top to fill out the panel.
All the switches extended
First attempt, Key Switch is too close to the toggle switches
Made another Wing Panel, This one looks better
