TAB Aircraft LLC Web Site
Date:  9-1-2013
Number of Hours:  1.50
Manual Reference:  N/A
Brief Description:  Page 332 Mounting the Viking Power Buss
September 2 2013
The Viking Power Buss is, according to Jan at Viking, supposed to be mounted under the panel.
In a SeaRey with an LSX Interior however, dose not have a convenient space under the panel to put it without being between your legs.
My intention was to cut the switch guard off and mount the entire power buss assembly to the LSX center stack panel by drilling the holes for all the switches and installing from behind the panel.
I did want to install a better looking switch guard to replace the one I cut off, but the toggle switches were to close, so I thought I could drill new holes in the Viking switch panel between old holes to spread out the switches. That did not turn out well and I ruined the Power Buss mounting plate.
So now I had to change my plans. I removed the Power Buss Assembly from the mounting plate and used the plate as a template to drill the holes in my Avionics Tray to mount the Power Buss on it without the plate.
Removed the switches to cut the guard off
Cut the guard off
Cut the guard off
Used the plate as a template
