TAB Aircraft LLC Web Site
Searey LSX
N/A
Page 301 Installed the Fuel Pump System
August 4 2013
I decided to put the fuel pump on a larger aluminum panel so I could add the Fuel Filter and Fuel Flow Transducer on the same panel.
I then attached the panel to the right side rear cockpit tubes with rubber cushioned clamps.
Searey LSX Home
800
Aircraft
Airframe
86
Background
Brakes
Cockpit
67
130
Education
Exterior Trim
Fly-In/Party
Gear Assembly
Hull
Interior Trim
Modifications
Turtle Deck
Wiring
53
131
Work Shop/Hanger
