TAB Aircraft LLC Web Site
Date:  5-13-2013
Number of Hours:  0.30
Manual Reference:  N/A
Brief Description:  Page 242 Installing Flap Position Sensor 1
May 15 2013
Another day with out a Plumbing call and looking for something to do, I installed the last Position Sensor on the Flap Horn lever.
The rod I used on this and the Trim Position Sensor I installed months ago is a Remote Control Model Airplane Servo Rod with a connection end that is perfect for this application
Remote Control Servo Rod with a connection end that is perfect for this application
Set the sensor with double sided tape
Marked the rod and horn after running the motor back and forth
