Brief Description: Page 144 A Trip to the SeaRey Factory 1
January 3 2013
I went to PA to pick up a Template that shows where to drill holes in the side of the Console for the upholstered panels that covers each side of the console.
While there, I told Kerry Richter about the Throttle/Brake Lever being to high to fit under the Console Top Cover. He showed me the fix for that. Remove the 2nd bolt and lower the Brake System Lever clamp to the lower bolt.
Works for me, Now I wont have to raise the back of the Console to clear that lever.
I love being near the Factory.
My lever with all 3 bolts on the Throttle Arm and the Brake System Lever clamped near the top
This one at PA had only 2 bolts and the Brake Lever was lower on the column
