TAB Aircraft LLC Web Site
Date:  9-19-2012
Number of Hours:  1.50
Manual Reference:  N/A
Brief Description:  Page 77 Installing Trim Position Sensor
September 20 2012
I Installed an Adjustable Control Rod for a Radio Control Airplane I got from a Hobby Store on the Sensor Arm, and two sided tape on the top of the Sensor and set the Sensor up side down on the Actuator. I ran the Actuator back and forth to test where to set the rod on the Trim Slave Arm.
I marked the spot for the hole on the Slave Arm. I removed the Slave Arm and drilled the hole and reinstalled the Trim Slave Arm. I inserted the Rod and test run the Actuator and adjusted the Rod till it pushed and pulled the Sensor Arm full in and out.
Trim Position Sensor and Adjustable Rod
Two Sided Tape on top of Sensor
Sensor Taped to the Trim Actuator
