Brief Description: Page 67 Brake Line Routing Part 4
September 11 2012
Attached the 1/4"OD tubing with the brake line inside to the back side of the upper Bulkhead with clamps. Then connected both sides to a Tee fitting and ran the brake line to the front through the left side Lower Outboard Cockpit Tube to the Battery Tray where the Parking Brake valve will be located.
Pilot Side
Copilot side
Ran the brake line to the front through the left side Lower Outboard Cockpit Tube
