Brief Description: Page 58 Installing Bushings Part 3
September 4 2012
MODIFICATION NUMBER 8
I disassembled the Control Column Torque Tube from the Elevator Push/Pull Tube and drilled out the connecting bolt hole to accept the Bushing. I installed the Bushing and half way drilled through the Plastic Saddles to clear the part of the Bushing that sticks past the Tube and reassembled the Control Column to the Push/Pull Tube.
