TAB Aircraft LLC Web Site
Searey LSX
S5- 12.1 to 21.2
Page 47 Permanently Attaching Airframe to Hull
August 22 2012
Section 5. Permanently Attaching the Airframe to the Hull
Manual Ref:S5- 12.1 to 21.2
Shimed the Stringer Mounts with Fender Washers.
Mounted the Aft Hull Mount Angles to the Transom and sealed the Bolts through the Transom
Drilled holes at the top of the Hull at the Bulkhead and ran the bolts through to the Bulkhead
Getting the Fender Washers in
Sealing the bolts through the Hull
Bolts through the Hull
Searey LSX Home
800
Aircraft
Airframe
86
Background
Brakes
Cockpit
67
130
Education
Exterior Trim
Fly-In/Party
Gear Assembly
Hull
Interior Trim
Modifications
Turtle Deck
Wiring
53
131
Work Shop/Hanger
