Brief Description: Page 43 Installation of the Bilge Pump
August 14 2012
Section 5. Installation of the Bilge Pump
My kit came with the Bilge Pump, but not the Bilge Pump Service Mount Plate (#5330-019) The clear plastic strip that the pump is attached to so you can replace the pump later with out sending your cat back there to unscrew the screws. I went to PA to get one. Its nice that I live 20 min. away.
I attached the pump to the strip and the strip to the Hull as per the Manual.
Installation of the Bilge Pump Connector to the Hull Manual Ref: S5- 36.1 to 36.3
I also skipped ahead and installed the Bilge Outlet on the Hull.
