Brief Description: Putting the frame into the hull Page19
After cutting and gluing in the carpet into the hull, we lowered the frame into the hull. The front brackets that connect to the stringer looked off, the stringer was not square in the hull. the back bracket would not line up with the transom angle. The frame needed to move back a quater inch or more but the front stringer was not in the right position and keeping the frame forward. Bill took pictures and went to PA and they made new u-brackets to give some aft movement.
