John B.s Web Site
Date:  7-12-2009
Number of Hours:  1.00
Brief Description:  Bracket for Fuel Flow Sensor
Make mounting bracket for the Flow Scan Turbine Fuel Flow Sensor. It took me most of the afternoon to figure out the best location for this sensor. It have to have a relatively stright input hose for 5" before the input side and about 2 inches after the output side.I believe I found a good location at the lower left side of the firewall.Will do the installation tomorrow. After the fuel flow sensor is mounted to the firewall I will have to re-configure the hose from the fuel pump to the sensor and to the carb.
