Riveted the rudder stops to the fuselage. The CS4-4 blind rivets were too short for the 2 forward holes, so I decided to used CherryMax rivets (CR3212-4-6. The two rear rivets were the CS4-4. The plan calls for regular rivets, but I was unable to use the rivet squeezer or the bucking bar at this location. I might decide to add an other rivet further back on the rudder stop that I can put in with the bucking bar.
