Install the Vetterman exhaust system. the male pipes in the slip joint have to be cut by 1 1/8" since the system comes made for the 360 engine. It is not easy to cut stainless steel. Tried fine (32) hacksaw blade, but it would have taken me an hour or more to cut the two pipes. Went with the Dremmel tool and high speed abresive disk. This made life a lot easier. Once this cut was made the installation was easy.The inside nuts are very difficult to get to, but it all worked out OK. I did not torque the nuts!!!!!!!!!!!!!!!!!!!!!!!!
