Install fuel pump fittings and hoses as per DWG OP-28 and Firewall Forward Installation instructions . The compression nut still have to be tightened after the carb is installed!!!!!!!!!!!!! Install the fuel pressure hose between the VA-168 and VA-128 fittings.
