Rivet the side and bottom hinges to the firewall and finish riveting the bottom part of the firewall to the fuselage between the two bottom hinges. This has been a very timeconsuming process since the bottom of the firewall lip is too close to the engine mount. I had to use crews and nuts for the two inside botttom rivet locations and the two lower side rivet locations.
