Reinstalled exhaust pipe to cylinder #1. A lot harder than taking it off. I had to take off the nuts on cylinder #2 to accomplish the task. The carb heat hose was especially dificult to put back. Ultimately I had to cut a new hose and fit it between the exhaust pipe and the carb heat inlet. The first picture shows the original location of the EGT probe. The second picture shows the new location and the weld under it.
