Brief Description: Check for fuel leeks on the cabin side
To check for fuel leaks on the cabin side I had to remove the cover for the fuel valve and the small cover to access the fuel pump. This is the cover where all the control cables pass though. Very difficult on the body; the access is not easy. After removing the covers run the gas pump and found no leaks. Put everything back. Took forever, I hope I don’t have to work under the avionics panel too many times.
