Bob Eggelston came over to give me a hand on putting some fuel into the tanks. Our plan was to get the fuel quantity that will start moving the float type fuel sanders. Although we realized we will not be able to calibrate the tanks at the tanks full position we wanted to check for leaks. WE found a few on the engine side. Tightening the connections solved the problem. There is no apparent leak on the cabin side. We will check this tomorrow. Will have to remove a couple of panels and start the fuel pump for a short time.
