Brief Description: Work on filler plates and wing jacks
After adjusting the filler plates I went ahead and sanded and cleaned them for priming. Drilled 3 attach holes in the base of each wing jack. Today I called the spinner done until the centering of the cone is finished at a later date. The wing jacks will be attached to a 2”x2”x3/4” plywood base using screws in the base of the jacks and 4 braces each made from 1/2” electrical conduits.
