Brief Description: Work on filler plate, wing jack
I continued forming the filler plates; getting closer. Purchased a 1 1/2" to 1" pipe reducer at R&R supply and cut the cup needed for the wing jack to wing tie-down rings. Cut these pieces as shown on the pictures. The one inch side of the reducer receives an all thread attachment which will fit over the top of the jack providing a secure attachment point to the jack. Since the first pipe fitting worked out good I went and picked up a second reducer to be used on the second jack setup.
