Install the labels for the Flap Switch, Carb Heat, Throttle and Mixture Controls. This was probably the most difficult to do, because there is very limited space to work in. I considered centering tha labels, but because of space limitation I had to put the labels along the lower edge of the brace. Actually came out pretty good. Also installed the lower and upper covers for the radio stack that I painted the previous day. The fit is very good.
