Spent most of my time placing several labels in different locations. Label placement is time consuming because of the difficulties of orienting the labels. The left "No Step" label didn't come out quite right, will see if I can replace it. The rest of the label are OK. (Fuel filler label, No Step label, Cabin Heat label, Carb Heat Full Out). I also looked at how to close the map box back. I considered using the aluminum angle (3/4x1/16 thick) on the outside or inside of the box). Roy Space came by to visit.
