I cut additional wooden support for the ful and brake lines for an area between the fuel selector valve and the fuel pump. I also modified (shortened) the two existing support pieces to allow more room for the cable bundle. Wil probably have to apply a small amount of glue between the wood supprt and the aluminum floor. Because the original elevator trim cable turned out to be too short I decided to run a new cable for the elevator trim and remove the old cable. Also run the flap indicator cable.
