Spent a little time and vaccumed up the fuselage and around the airplane. Bundle and label the wires connected to the GPS and AOA swithes. The wires that connect to the battery bus are also maked with blue heat shrtink tubing. To make these wires removable I used a screw terminal. Going from right to left the first connection is for the GPS power through the switch. The second connection is for the AOA power that will be installed next. The third connection is for the EIS warning light. The third image is a good picture of the battery bus.
