Brief Description: Autopilot harness and strobe wires
Pull the autopilot roll servo harness through the main spar and out to the right wing connection point. I used the through hole I drilled a couple of days ago in the mail spar. The strobe wires had to be extended to reach the power connection point behind the left avionics panel. To connect (extend) wires I used the method described in Bob's Shop Notes: Poor Man's Solder Sleves (www.aeroelectric.com/articles/PM_Solder_Sleve/PM_Solder_Sleve.html). This works quite well, just takes a little time to do it right.
