Brief Description: Install snap bushing, Drill Center Spar Carry Thro
Install snap bushing in all the trhough holes behind the center spar. Reinstall the strobe wires for the left and right wings. This should have been done before installing the control stick. Live and learn. Drill two center spar through holes (5/8") for the wires that go between the panel, the wings and the fuselage. These holes are located under the two gear weldments. Installed 4 snap bushings. This was a real difficult job because of the tight quarters I wish I did this at an earlier date when things were wide open.
