Brief Description: Power and ground connection for autopilot & clock
Make power and ground connection for the autopilot using the on off switch installed earlier. Since the autopilot is on the avionics bus I felt it was necessary to provide a separate on/off switch for the autopilot. Connect the power wire for the clock through the clock switch installed earlier. The clock will use the battery bus and a local ground connection.
