Started laying out the harness route for all the cables that go to the wing, empennage and the control stick. Install the first clamp that holds the wire bundle for the auto pilot, magnetometer, fuel level sensor, and outside air temperature. I will run these wires behind the firewall along the fat power cable, down on the right side of the center console and under the center console to and through the main spar.
