Installed the ground block on the firewall on the cockpit side. Right now I don't see any need for a grpound block on the engine side. It will be easy to install if needed. I put the nuts and washers on the cockpit side to have more clearance for removing the battery if needed. Since I already installed a platenut for the braided grouind wire according to plans, I moved the ground block a little to the right ourboard side of this location and connected the two with a copper plate. This will give me more flexibility to install the engine ground and the battery ground at the same location.
