Make the final cut on the F7105 Center Sub Panel for the SL 30 and the GTX 330 opening. This was a fit and cut operation with a number if repeats. Will use stiffener angles to make the structure of the Sub Panel stronger. The two large holes along the upper edge will be cut out for the GMA 340 cable assembly. It sure is difficult to work in the small space of the cockpit.
