Cut the clearance holes in the F7105 Center Sub Panel for the SL 30 and GTX 330. This is the first rough cut after I projected the location of the two mounting trays. I used the Dremmel tool to make the cut. This is a tight environment. Only the SL 30 and the GTX 330 is long enough to need this opening.
