Brief Description: Extend Air Inlet lip to bottom plate of filter
I have to extend the lip of the VA-199A Air Inlet to the bottom plate of the filter. I used a styrofoam plug through the hole in the Air Inlet that extended to the bottom plate. On the inside I made a styrofoam rin that gave me about 1/8" ring. I will fill this with fiberglass epoxy mix. After cure and sanding I will use hi-temp gascating silicome for the final seal.
