Fitted the WigTips on the wing to see if the trailing edges still line up. Bad news!! The weight and the drying glue apparently moved the trailing edge and things dont line up any more. So take everything apart clean the surfaces from the glue. The second time, no pressure on the WingTip. Re-draw the position of the W-931 rib on both Tips, spread the thickened T-88 glue on the inside of the Tips and carefully position the ribs as per Page 7-16 instructions. Actually the capillary action of the glue held the tip skin next to the rib flanges. Wait overnight for the glue to dry.
