Mark the location of the hold down pins and drill two wood hold down blocks for the left and right side. This was necessary so I could verify the acuracy of my drill jig. The jig came out almost perfect. The holes lined up with the pins. Mark and drill the plastic blocks. The left side needed more adjustment by rotating the drill bit, but the right side came out perfect the first time. Drill the side screw locations on both side and install the screws.
