Drilled the holes for the canopy slide rail on the left side. Made a wrench to fasten the screws that hold the slide rail. This is otherwise impossible to get to. Before the canopy slide rail is installed I had to remove the F-705G-L Angle that was installed on the quick build fuselage for the tipup canopy. To do this I had to drill out the temporary pop rivets holding the angle and the F-757 Gusset. I also radiused the F-757 Gusset as per DWG 42 Detail B. Deburred the circular cut on the F-757 Gusset and the rivet holes, clecoed everything together.
