Test fit the two canopy part on the fuselage. Everything is loose and not clamped down, but things look pretty good. Will have to lower the canopy part by cutting the tube at the rollers by about 0.25". Looks like shims will have to be used on the roll bar. Next I will fit the windscreen to the forward fuselage skin, since this will slightly change the angle on the windscreen at the roll bar.
