Fished the pitch servo wires through the conduit, installed the 9 pin connector and installed the connector on the elevator servo. Since this is my first time with the 9 pin connector, it took longer than required. The conduit runs paralell with the small elevator push rod. This arrangement will keep the wires from interferring with the push rod. The trim servo wires will fit in the same conduit. Stein Air made up the wireing harness.
