Attach the ground wire to the F-601N-R stiffener on the firewall. I was going to use the fuel pump mounting screws, but since I already tightened these screws, I drilled a #19 hole on the stiffener and used a screw/washer/lock washer/nyloc nut combination. Also sanded the area behind the screw head for better conduction.
