Remove the F-7108A center forward fuselage rib with the F-7105A Subpanel, the F7109 plate and the F-7108B angle from the fuselage. The entire Front Deck was temporarily clecoed to the fuselage at an earlier date to fit various fuselage components. Riveted these pieces together as per DWG 24. This could have been made easier by disassembleing the mid-rib components, but to put the rib/angle assembly back into the subpanel is almost impossible so I decided to rivet the pieces together without taking them apart. Although it was time consuming to keep al the lose pieces together while riveting, I am glad I went this route. Reinstall the rib/plate/angle/subpanel assembly into the fuselage.
