Insert the F-982C between the center floor reinforcement angles and the F-601N vertical angles on the firewall. Check to see that an even amount of the horizontal section of F-982C is exposed above the floor angles. Adjust the F982C for/aft until it mates with the bottom of the F-983C Fuel Valve Cover. Fasten the two parts together. Fit the forward section of the F-982C to the firewall and F-601K-1 firewall recess. Drill the F-982C to the floor stiffener angles and to the F-601K-1 firewall recess. Install 4 platenuts on F-982C and 2 platenuts on F-601K-1. Fit F-982C to fuselage.
